Clutch Hub assy's
joeweir1
Clutch Hub assy's
Post by joeweir1 » Wed May 09, 2007 6:47 pm
I have two different styles of clutch hub assy's from some CA77's I tore down.One on the left is from a later production than the one on the right.Is one better than the other ?Check the picturs out.
Re: Clutch Hub assy's
Post by LOUD MOUSE » Wed May 09, 2007 9:45 pm
Use the ones on the left and the main hub that came with them.
Also use the friction disc with the aluminum cores and you will have the Cush Drive that was/is the last clutch that Honda used in these engines. ........lm[
quote="joeweir1"]I have two different styles of clutch hub assy's from some CA77's I tore down.One on the left is from a later production than the one on the right.Is one better than the other ?Check the picturs out.[/quote]
