Still no luck.
All told I have been soaking the threads of these screws for 2 weeks. have used WD40, CRC Power Lube, PB Blaster and Liquid Wrench. I've turned the tank upside down and soaked the heads of the screws, I've had it right side up and puddled PB Blaster in the bottom of the tank to soak them from the other end. I've used an impact driver on the screws too, they have not budged.
So, if I drill the heads off and remove the petcock is there going to be enough screw shaft sticking up to grab with vice grips? Are the nuts the screws mate to welded to the bottom of the tank or will the shaft and nut simply fall loose into the inside of the tank?
CA77 Petcock Removal
- Contact:
Tried the impact driver, no joy.
I did get ONE screw out today. After my last post I was taking a new cordless drill I bought today out to the garage and on a lark I popped a phillips into the chuck, set torque to max, put it onto one of the screws with all the weight I could and lo and behold it backed out! No such luck on the remaining two. The one that came out was VERY rusty.
