rich/lean conditon on CA77
joeweir1
Post by joeweir1 » Sat Aug 18, 2007 9:43 pm
One plug looks lean and the other looks rich when I pull them.Not sure how to procede on this one.Could it be a valve adjustment since one side is rich?Joe
Re: rich/lean conditon on CA77
Post by LOUD MOUSE » Sun Aug 19, 2007 8:02 am
Could be valves and have ya checked the compression of the cylinders? .....................lm
joeweir1 wrote:One plug looks lean and the other looks rich when I pull them.Not sure how to procede on this one.Could it be a valve adjustment since one side is rich?Joe
joeweir1
Post by joeweir1 » Sun Aug 19, 2007 6:47 pm
Ed-I was out adjusting the valves today.Should these valves on thes bikes be real quite when adjusted properly or should I hear any valve tap at all?Hope that is not a dumb question?Started to rain so I really can't test drive it for another day or so.I have not checked the compression.No gauge right now.thanks
Post by LOUD MOUSE » Sun Aug 19, 2007 7:12 pm
When set to .004 you will hear the engine because it's aluminum but the tappets should be quiet. .............. lm
joeweir1 wrote:Ed-I was out adjusting the valves today.Should these valves on thes bikes be real quite when adjusted properly or should I hear any valve tap at all?Hope that is not a dumb question?Started to rain so I really can't test drive it for another day or so.I have not checked the compression.No gauge right now.thanks
joeweir1
Post by joeweir1 » Sat Aug 25, 2007 11:55 am
Mouse-Finally the rain stopped and was able get the bike out after adjusting valves.Seems now the engine is noisy(tappets I guess) and I did take it for alittle ride and when I checked the plugs they both looked the same.Before one looked lean while the other looked rich.I would say they look closer to what they should be now.Now I guess I should try to readjust the valves alittle tighter.I guess they are alittle off(maybe not all) of the .004.Bike was quiet before I adjusted them.Joe
