Grease zerks/fittings..........
cribbs74
Post by cribbs74 » Tue Sep 25, 2007 12:16 pm
All,
Is there supposed to be a grease fitting in the speedo cable drive? Just cleaned mine up and noticed a little threaded hole, also noticed a bung hole in my frame on top of the swingarm bushing that has no zerk, I am guessing one was supposed to be fitted there as well?
Are they available in correct thread pitch off the shelf or do I need to order them?
Thanks,
Ron
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
ggray
zerks
Post by ggray » Tue Sep 25, 2007 2:13 pm
Ron,
The zerks are not threaded, They're press in. Youf swingarm has one in the swingarm pivot bolt end and one in the swingarm itself. Total of four for the bike. Two on the RH side cover and two on the swingarm assy as described above. Ohio Cycle has them.
Gary
'65 CL77 Owner
cribbs74
Post by cribbs74 » Tue Sep 25, 2007 8:28 pm
ggray,
I see, however what is the small threaded hole for in the speedo drive unit?
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
ggray
zerks
Post by ggray » Tue Sep 25, 2007 10:40 pm
Ron,
You talking about the one that attaches to the lower RH fork slider?
I'll look at mine tomorrow and get back with you. I don't remember a hole. Perhaps a srew is missing on yours.
Can you post a pic?
Gary
'65 CL77 Owner
cribbs74
Post by cribbs74 » Wed Sep 26, 2007 7:50 am
Gary,
I am referring to the round aluminum speedo drive that the front axle goes through and rests against the front hub. The speedo cable screws onto it. My camera takes 1 meg pics so I need to figure out how to make them smaller before I can post.
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
redblk63
zerk fitting on front hub at speedo drive?
Post by redblk63 » Mon Feb 08, 2010 3:54 pm
Ron,
I have the same question as you did and am curious if you ever found an answer. It sure looks as if that screw on the speedo drive hub is a placeholder for a screw-in grease fitting.
Larry Young in Pasadena
cribbs74
Post by cribbs74 » Tue Feb 09, 2010 7:07 pm
No resolve on this one, I did install the correct screw in there though. I suppose you still could screw in a grease fitting, but the threads may be an issue.
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
