SWINGARM AND BEARING CUPS
DCON
Post by DCON » Wed Oct 24, 2007 5:21 pm
JUST GOT MY FRAME AND SWINGARM BACK FROM POWDER COATERS, SHOULD I SAND THE I.D.S OF THE BUSHING HOLES BEFORE PRESSING IN THE BUSHINGS AND RACES?
4shorts
Post by 4shorts » Wed Oct 24, 2007 5:59 pm
I sure would! Paul
1964 CT200
1965 C78 305 Dream
1966 C100 Cub
1966 C200 90 Touring
1969 Z50AK1
1972 C70 Cub
1972 CT70 K1
1984 C70 Passport
2003 GL1800 GoldWing
Rhino
Swingarm rear wheel dampers
Post by Rhino » Fri Jul 11, 2008 1:25 pm
Hey there...sounds like you are well on your way with your project...I am on my way to the powdercoat shop as well, but need to remove those damper....how did you get the old one's out, it there a tried and true method....thanks for your time in advance....
Rhino
swingarm rear wheel dampers
Post by Rhino » Fri Jul 11, 2008 2:30 pm
Never mind, but thanks for your consideration, I presssed it out with an oversize socket, a threaded bolt and some washers...they came right out.......thanks again
Rhino
swing arm fit
Post by Rhino » Sat Aug 02, 2008 2:38 pm
Hello all...just got my CL77 frame back from the powder coat shop and I cannot get the swing arm to fit with the two dust seals on the inside....I have filed off all the sufaces of any powder coat but simply cannot get it to fit....any ideas as to what happened to the fit and how I might get it in there.....only one washer/dust seal will fit, I cannot get the other one in on the other side....thanks....
