sprockets.
I plan on taking this thing on road trips, although there are certainly better bikes for this, I'm a smaller guy, and i think it'll manage fine.
what's a good sprocket size/ratio for me to think about for such things? I guess gas mileage is the number one concern with top end speed being the second concern (really, the less stress i can put on the engine at 80mph the better). having a lot of pick up off the line isn't a concern.
1965 Superhawk CB77
I recommend 15 = 32. Plenty of top end and easier on the clutch starts. ..................lm
Gun wrote:sprockets.
yay!
moving right along.
a few questions. what are you guys doing about air filters? what battery are you folks using?
and i sheered the ... grounding bolt?... on what i believe to be my starter motor (take in mind i don't know much about motorcycles at all, this is my first bike, and i've done minimal work on any vehicle whatsoever, BUT my logic tells me its the starter motor).
It's a hollow bolt, and connected to all that jive wire coiling inside and now i've nothing to connect that ground to. should i just purchase a new one (think i found one on ebay) or is there a route around this with limited tools?
thanks guys!!![/img]
???????????? A pic would be a big help. ........lm
Gun wrote:
yay!
moving right along.
Use the search option on this site for air filter ideas, there are plenty of them. That is the positive wire from starter selenoid to starter motor that gos to the bolt you broke. It is fairly simple to disassemble starter motor, but it may be hard to find a replacement bolt, and it may need to be soldered in. I suggest replcing it. They are on ebay all day long, and you can use either CA or CB 72 or 77 starters. If you are talking about cruising at 80mph, go with a 15-30, or even 15-29.
