Offset rear wheel
- swampyankee
Offset rear wheel
Take a look at the photo below. Does the rear wheel look oddly offset to the right? I changed out the counter-sprocket and found excessive wear on the left side, which would go with the right-offset as well. The spacers are in the right places - large one on the left - per the book. I've checked the swingarm and it appears to be square and straight. I see no evidence of damage to indicate a bent frame. I'm tempted to just cut down the spacer on the left and add a piece to the right to center the wheel. Any suggestions or ideas before I do that?
Bikes:
'79 BMW R100RS
'03 HD Sportster 883R
'66 Benelli Sprite
'64 Honda CL72/CL77 motor
'79 BMW R100RS
'66 Benelli Sprite
Re: Offset rear wheel
Tis possible that some time back a previous owner used the wrong spacers. If you will measure both spacers I will check through my spares for ya. The CL77 bikes used similar but different length spacers. .......................lm
swampyankee wrote:Take a look at the photo below. Does the rear wheel look oddly offset to the right? I changed out the counter-sprocket and found excessive wear on the left side, which would go with the right-offset as well. The spacers are in the right places - large one on the left - per the book. I've checked the swingarm and it appears to be square and straight. I see no evidence of damage to indicate a bent frame. I'm tempted to just cut down the spacer on the left and add a piece to the right to center the wheel. Any suggestions or ideas before I do that?
- swampyankee
Hard to get an accurate measurement without taking it apart, since the right side goes under the seal, but it looks like the right one (chain side) is a bit over 3/4" (maybe 20mm) and the left is just about 1-17/32" (39mm?).
Bikes:
'79 BMW R100RS
'66 Benelli Sprite
'79 BMW R100RS
'66 Benelli Sprite
No actual measurements no fixie!!!!!!!!!!!!!!!. ...................lm
swampyankee wrote:Hard to get an accurate measurement without taking it apart, since the right side goes under the seal, but it looks like the right one (chain side) is a bit over 3/4" (maybe 20mm) and the left is just about 1-17/32" (39mm?).
- swampyankee
Those are actual measurements, taken with a 6" machinists scale. they're probably accurate to within 1/32". I slipped the scale under the seal on the right side. I'm a tool maker by training so "accurate" to me is within +/- .002"
Bikes:
'79 BMW R100RS
'66 Benelli Sprite
'79 BMW R100RS
'66 Benelli Sprite
