Hi Guys
Can any of you please advise me of the diameter of the combination switch hole in RH aircleaner cover of the CL72. I am trying to get the detail correct for my bike.
The diameter changed with a modification of the switch at frame number CL72 1001045.
If someone can tell me their frame number and hole diameter I can work out if what I have is correct or not.
aircleaner cover
Side cover
Do you have the type ignition switch that is attached with two flat head screws through the frame bracket?
'65 CL77 Owner
Hi ggray
Thanks for you interest !
The ignition switch is missing completely at the moment ! The mounting point does have the two bolt holes but I think this may have been "modified at some stage as my frame number suggests it should not have that type of switch.
I was hoping someone could measure a side cover hole diameter from a bike that is "original" and I could then compare it to mine and tell if it has been enlarged at all?
Side Cover
I'll measure mine tomorrow (Saturday) and let you know what the diameter is.
Gary
Gary
'65 CL77 Owner
