Githianki
Post
by Githianki » Fri Nov 30, 2007 7:04 am
How clean does/should the stator be? Apparently the seal on that side of the engine leaks and will need to be replaced. The whole stator was covered in oil, and I want to clean it off. Can I use some modern electrical contact cleaner on it? Or is there something else I should be using?
Superchicken
Post
by Superchicken » Fri Nov 30, 2007 7:46 am
In my opinion, it is not necessary to get it very clean. A little WD40, and a soft tooth brush if you want to remove some of it is OK. You could do damage to the insulation if you try too strong of cleaner. The stator will be fine, if it is not perfectly clean.
Githianki
Post
by Githianki » Fri Nov 30, 2007 8:45 am
Yeah, I know it doesn't have to be sparkling pretty, but there is a significant amount of oil and crud on it to warrant a little dust up.
Post
by LOUD MOUSE » Fri Nov 30, 2007 8:48 am
I wash those in parts cleaner. (NOT CARB CLEANER). .....................lm
Githianki wrote:Yeah, I know it doesn't have to be sparkling pretty, but there is a significant amount of oil and crud on it to warrant a little dust up.
Githianki
Post
by Githianki » Fri Nov 30, 2007 8:50 am
LOUD MOUSE wrote:I wash those in parts cleaner. (NOT CARB CLEANER). .....................lm/quote]
So as long as it's not too harsh, and something that wont harm plastic I should be fine...
