Has anyone found a source for either
a: levers w/ 8mm mirror mounts or
b: mirrors with 10mm threads
Ebay has lots of the wrong stuff, which look good with the obvious exception of having the wrong threads to match the other part. I am replacing both parts on my project, and ebay is good for both 10mm levers or 8mm mirrors.
levers & mirrorsmirrorsHad the same problem with my CL.
Had to make stainless inserts from 12mm bolts. I drilled and tapped the mounts for a 12mm thread, cut and drilled 12mm bolts with 8mm ID and installed them flush in the 12mm tapped holes. Worked great and now I can use the 8mm mirrors with no worrys. Good luck. Gary '65 CL77 Owner
