Leaking Petrol Cap
Phil-UK
Leaking Petrol Cap
Post by Phil-UK » Fri Mar 07, 2008 9:07 am
I am getting annoyed with this so am seeking advice.
When I restored my CB72 the petrol cap leaked if you filled the tank within 1" of the top; not just a
dribble but a proper "slop" down the side.
Since then I have tried bending bits of the cap, tweaking the lip of the opening in the tank and of
course replaced the cork washer ( and tried soaking it first so it swells up ) - all to no effect.
This is just a nuisance on short runs but will be a real pain if I go to France during the summer
and need to fill it up.Its also an MOT ( Ministry of Transport ) test fail so I always take it to be
tested with a near empty tank.
My thoughts are that maybe the top of the tank was bashed at some point and the opening is
lower than it should be - hence the cork washer doesn't seal against anything; but I don't have another tank to measure it against.
Any ideas, comments or measurements ( height of lip of opening above tank ? ) would be
most welcome,
thanks
Phil Lou ( UK )
ggray
Petrol cap
Post by ggray » Fri Mar 07, 2008 8:39 pm
Could be the "LIP" has a ding or low spot that is not letting the gasket seal properly.
When prepping my tank, I used a straight edge and a file backed piece of sandpaper to "level" out the filler lip. If I showed a low spot, I bumped the inside surface to bring it back to height. So far, so good. I also am using a rubber gasket, not the cork.
Gary
'65 CL77 Owner
Phil-UK
Post by Phil-UK » Mon Mar 10, 2008 6:32 am
Thanks Gary - will see if I can find a suitable piece of rubber, well worth a go.
Phil
ggray
Gas cap
Post by ggray » Mon Mar 10, 2008 7:39 am
Not sure, but try www.cmsnl.com They may have them.
They're in the Netherlands
If not, try www.classichondarestoration.com here in the colonies.
It's where I got mine
Gary
'65 CL77 Owner
Buck
Post by Buck » Tue Mar 11, 2008 9:59 pm
The rubber gas cap gasket is still available from your local Honda dealer.
