Gasket material for cases
What do you guys use for gasket goop when putting the cases back together? I have some stuff that Loctite makes we use at work all the time when putting things together. Will that be good enough?
Re: Gasket material for cases
I use Yamabond 4 or Hondabond 4..............................lm
Githianki wrote:What do you guys use for gasket goop when putting the cases back together? I have some stuff that Loctite makes we use at work all the time when putting things together. Will that be good enough?
