PDO::ERRMODE_EXCEPTION, PDO::MYSQL_ATTR_INIT_COMMAND => "SET NAMES utf8mb4", ] ); // newest completed CA entry (via view) $sql = " SELECT model_year, model, ADM_StateOrProvince, ADM_Country, condition_value, opinion_value_today FROM h305_ca77_entries ORDER BY submitdate DESC, id DESC LIMIT 1 "; $row = $pdo->query($sql)->fetch(PDO::FETCH_ASSOC); // casing helpers (same pattern as CB / CL) $keepCaps = static function (string $w): bool { return (bool)preg_match('/[A-Z]{2,}/', $w) || (bool)preg_match('/\d/', $w); }; $word = static function (?string $w) use ($keepCaps): string { if ($w === null || $w === '') return ''; if (strpos($w, '-') !== false) { $parts = explode('-', $w); foreach ($parts as &$x) { $x = $keepCaps($x) ? $x : ucfirst(strtolower($x)); } return implode('-', $parts); } if ($keepCaps($w)) return $w; $dot = substr($w, -1) === '.'; $base = $dot ? substr($w, 0, -1) : $w; $done = ucfirst(strtolower($base)); return $dot ? ($done . '.') : $done; }; $title = static function (?string $s) use ($word): string { if ($s === null) return ''; $s = trim($s); if ($s === '') return ''; $t = preg_split('/\s+/', $s) ?: []; foreach ($t as &$x) $x = $word($x); return trim(implode(' ', $t), ", "); }; if (!$row) { $line = 'Latest Registry Entry: No completed entries found.'; } else { // location like "WA, Australia" $region = $title($row['ADM_StateOrProvince'] ?? ''); $country = $title($row['ADM_Country'] ?? ''); $loc = trim( implode(', ', array_filter([$region, $country], fn($v) => $v !== '')), ', ' ); // normalize opinion_value_today using the same rules as CL: // - >=1000 => use as-is ($12500 => $12,500) // - 100..999 => treat as dollars ($750 => $750) // - 1..99 => treat as thousands (6 => $6,000) // - otherwise => "Not Entered" $valFinal = 'Not Entered'; if (isset($row['opinion_value_today']) && $row['opinion_value_today'] !== '') { $n = (float)$row['opinion_value_today']; if ($n >= 1000) { $valFinal = '$' . number_format($n, 0); } elseif ($n >= 100) { $valFinal = '$' . number_format($n, 0); } elseif ($n > 0) { $valFinal = '$' . number_format($n * 1000, 0); } } // condition code translation — same dictionary as CL plus "Rat" $condRaw = $row['condition_value'] ?? ''; $condMap = [ 'E' => 'Excellent', 'Exc' => 'Excellent', 'G' => 'Good', 'Goo' => 'Good', 'F' => 'Fair', 'P' => 'Poor', 'Par' => 'Parts Bike', 'R' => 'Restored', 'Res' => 'Restored', 'Rat' => 'Rat', ]; $condNice = $condMap[$condRaw] ?? ($condRaw !== '' ? $condRaw : 'Not Entered'); $line = 'Latest Registry Entry: ' . ($row['model_year'] ?? '') . ' Honda ' . ($row['model'] ?? '') . ' — ' . $loc . ' — Condition: ' . $condNice . ' — Value: ' . $valFinal; } // stamp + UTF-8 $built = (new DateTime('now'))->format('Y-m-d H:i:s T'); $stamp = ""; $charset = ''; $html = $charset . "\n" . $stamp . "\n" . $line . "\n"; // write to shared include $jobDir = __DIR__; $includeDir = '/home/mstoic3/public_html/shared/include'; $includeTmp = $includeDir . '/latest_ca77.tmp'; $includeDst = $includeDir . '/latest_ca77.html'; $jsonPath = $jobDir . '/latest_ca77.json'; $logPath = $jobDir . '/logs/latest_ca77.log'; // future optional if (!is_dir($includeDir)) { if (!mkdir($includeDir, 0755, true) && !is_dir($includeDir)) { throw new RuntimeException("Failed to create include dir: $includeDir"); } } if (file_put_contents($includeTmp, $html, LOCK_EX) === false) { throw new RuntimeException('Failed to write temp include file'); } if (!rename($includeTmp, $includeDst)) { @unlink($includeTmp); throw new RuntimeException('Failed to move include into place'); } @file_put_contents($jsonPath, json_encode([ 'line' => $line, 'stamp' => $built, 'ts' => date('c'), ], JSON_UNESCAPED_UNICODE)); echo "OK\n"; } catch (Throwable $e) { error_log("[generate_latest_ca77.php] " . $e->getMessage()); if (function_exists('http_response_code')) { @http_response_code(500); } echo "ERROR\n"; exit(1); }
Clutch Center Springs and Bolts
Dogsbd
Post by Dogsbd » Sat Mar 15, 2008 3:34 pm
Finally getting back to working on my CA77 project and I find a bolt broke off in the clutch center and of course a spring is missing as well. I order a spring and a bolt from my local Honda dealer before I completely disassembled the clutch (a mistake, I know).
Per the 1968 CA77 parts book I order:
22401-266-000 Clutch Spring
92101-06016 Clutch center bolt
The bolt comes in as a 92101-06016-0A and the spring is now a 22401-425-000.
I then pull out the clutch and remove the springs, plates etc. Finally get the broken bolt out too. Then I realize the remaining 3 bolts coming out of the center are about 10mm longer than the 16mm bolt I ordered per the parts book. Not a big deal I can pick up a longer bolt anywhere.
But then I notice the springs are longer than the one I ordered as well. The new one is ~34mm long and the old ones are ~36 mm long.
Unlike the bolt length, this does bother me. Do I order 3 more like the one shorter new one and use the shorter ones or do I need another that matches the longer length older 3 in the clutch? If I need to match the longer length, where do I get one?
After going back and double-checking myself in the parts book I now notice that it is not exactly clear on these springs as it calls for:
Qty of 4 of 22401-266-000 "Spring, clutch" on C77E serial A10001 .......
And then it also calls for:
Qty of 3 of 22411-266-000 "Spring, clutch free" on C77E serial A10001 …….. CA77E 211570
Any advise?
Re: Clutch Center Springs and Bolts
Post by LOUD MOUSE » Sat Mar 15, 2008 8:11 pm
From the first to the last year of issue of these bikes HONDA made MANY CHANGES to ALL THE PARTS OF THE CLUTCH. At least 4 outers and 5 inters and 2 pressure plates along with 4 springs and 3 steel disc and 5 friction disc. NOW WHAT WAS YOUR QUESTION? MATCH THE SPRINGS AND BOLTS FOR SURE. ............lm
Dogsbd wrote:Finally getting back to working on my CA77 project and I find a bolt broke off in the clutch center and of course a spring is missing as well. I order a spring and a bolt from my local Honda dealer before I completely disassembled the clutch (a mistake, I know).
Any advise?
Dogsbd
Post by Dogsbd » Sun Mar 16, 2008 8:11 am
LOUD MOUSE wrote:NOW WHAT WAS YOUR QUESTION? MATCH THE SPRINGS AND BOLTS FOR SURE. ............lm
So I take it that 34mm or 36mm length springs doesn't matter so long as they're all the same.
Post by davomoto » Sun Mar 16, 2008 9:04 pm
I just did a CB77 clutch with the 425 spriings, and it is sweet. The pull is nice and light. Another member, Vince Lupo, also recently did his clutch with these springs, and is thrilled as well.
Dogsbd
Post by Dogsbd » Sun Mar 16, 2008 10:24 pm
davomoto wrote:I just did a CB77 clutch with the 425 spriings, and it is sweet. The pull is nice and light. Another member, Vince Lupo, also recently did his clutch with these springs, and is thrilled as well.
Thanks, I'll order 3 more.
Return to “Transmission”
