Timing set-up on my CA77
Post by LOUD MOUSE » Wed Mar 26, 2008 9:16 pm
If that's what it does ya may want to split the difference with the first setting and run it. ..............lm
joeweir1 wrote:ok-I will have to go over it again,but after setting it seems one mark stays dead on and the other is off.Seems to stay consistent, but I will check it out again.
joeweir1
Post by joeweir1 » Fri Mar 28, 2008 7:07 am
Thanks LM-I was thinking the same thing.I was in the process of working out some bugs on another cleaned-up carb I put on.Was rich at idle with original parts,so I pulled the needle and moved the clip up to the second notch and I believe that cleared it up.Other carb ran with clip in middle?I did seem to lose some top end speed with the carb. swap for some reason.Joe
