Starter
SIDECAR77
Starter
Post by SIDECAR77 » Wed May 28, 2008 11:31 pm
?? when I push starter button the starter turns motor for only a few moments and then seems to let go and I get a nasty sound of skiping teeth. Does anyone know what this could be before I tear it down.
Thanks
Re: Starter
Post by LOUD MOUSE » Thu May 29, 2008 2:58 am
Pull the right side cover and watch. ......................lm
SIDECAR77 wrote:?? when I push starter button the starter turns motor for only a few moments and then seems to let go and I get a nasty sound of skiping teeth. Does anyone know what this could be before I tear it down.
Thanks
RIDE IT DON'T HIDE IT!
Jim Stuart
Starter
Post by Jim Stuart » Thu May 29, 2008 9:40 am
Could also be timing is way off, firing way ahead. Starter clutch is ratcheting.
Jim
SIDECAR77
Post by SIDECAR77 » Thu May 29, 2008 9:41 pm
Thanks guys, I re set the timmig and need gas so I will try tommorow, I have another stupid ?? when setting the points .014 is it set on the lobe and breaker or the contact and plate, and where should the mark on the lobe be pointing.
thanks
