Greetings,
A question if I may…
I have a 64 CA77, runs very well, however after an hour of riding the clutch lever gets stiffer and stiffer, and the lever travels less and less.
It also does not pull all the way in after the “Stiffness” starts.
I just got home from a 2 hour ride and my left hand is killing me as a result.
Seems the cable may be sticking, also making neutral hard to find…
Any suggestions?
Thank you in advance…
Scotty..
Stiff Clutch?
you might try oiling the cable. also make sure the lever mechanism inside the right side case is clean and greased. also if the big slotted adjuster on the side of the case is adjusted to far, it puts the lever in a position where it doesn't have the best advantage. sorry about the caveman drawings.
