ca77 carb removal
Before you toss the carb,
Drill out the center of the jet and try an EZ out. I don't like EZ outs and I usually don't suggest anyone use them however in this case if the EZ out breaks then you are no worse off than when you started and you can just toss the carb. If it works than you saved the carb ................ Good luck Ron Cribbs
1966 CL77 1965 CB160 1974 Triumph T150V
