CB160 seal replacement
CB160, CB350, CB360, CB450
Geeky160
Post by Geeky160 » Sat Jul 26, 2008 2:32 pm
So I need to change this leaking drive shaft seal out. Any tips that might keep me from really screwing things up?
Thanks
Image[/code][/url]
'67 CL77 (337, gears X'd)
'65 CB160
cribbs74
Post by cribbs74 » Sun Jul 27, 2008 1:43 pm
Good timing....
I just did this yesterday on my cl77. By the look of the picture it's nearly identical. I used a slide puller with a screw type attachment drilled a small hole in the seal screwed in the the puller and with one pull it popped right out.
LoudMouse suggests you chamfer the edges of the case so the new seal goes in easier, it's a real tight fit. I used a wood dowel and hammer to gently work mine in place. Took about 20 mins max.
Good luck!
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
Geeky160
Post by Geeky160 » Sun Jul 27, 2008 6:59 pm
Thanks cribbs, didn't have a slide puller so I made do with part of a curtain rod, some weird washer, wood screws and a brick. Tapped it in with a BF washer, spark plug socket w/ extention and hammer. Went smoothly once the "Yankee" kicked in. Thanks much!
'65 CB160
cribbs74
Post by cribbs74 » Mon Jul 28, 2008 4:51 pm
Glad it worked well for for you.
Love that tool!
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
