Geeky160 wrote:I've had nothing but trouble with the Keyster kit bowl gaskets. They are not like the factory gaskets. I've trimmed mine down several times and out of the blue (today) the float will hang up and overflow.
CA77 Carb Rebuild - Float Valve?
Is the carb a round bowl or a square bowl?. ..................lm
RIDE IT DON'T HIDE IT!
Float gasketsGeeky,
I too had a problem with leaky bowl gaskets using the Keyster gaskets. I finally solved the problem by installing OEM Honda gaskets (PN 16129-268-004), still available through Honda. Gary '65 CL77 Owner
Float gasketsGeeky,
No - the square variety. The Keyster gasket's corners are too squared off even for my square bowl. It has a more radiused corner. There is no way to make the Keyster gasket work on my bike even with trimming. One would have to trim the sharp corner off, but it would not leave enough material to stay together or stop gas from leaking. Should have taken a pick. You can easily make your own bowl gasket. Just get some gasket material from your favorite auto parts store and measure, trace or whatever (if you have the old one as a pattern, all the better) then just cut it out with an x-acto knife or even some good sharp scissors. I've made dozens of gaskets this way, eveything from valve covers to crankcase covers. Some pretty complex ones too.
Hmm, I tried doing that with some gasket material I got at NAPA. Got it trimmed up real nice but it leaked when I filled the bowl. I dont think it was compressing enough to seal. Maybe it was the wrong material. '67 CL77 (337, gears X'd)
'65 CB160
