65 Dream won't run without full choke
Post by LOUD MOUSE » Thu Aug 07, 2008 10:51 am
1 1/2 open from bottom then adjust the slide screw. ......................lm
djbarcy wrote:Now there's an interesting question.
If it is the one just under the frame that sticks straight out (as opposed to the other one that is closer to the motor and in at an angle), I have tried it everywhere from all the way in to out 3 or 4 turns and there is not much change.
RIDE IT DON'T HIDE IT!
nevada72
Post by nevada72 » Thu Aug 07, 2008 3:53 pm
Doesn't that mean it's running too lean? Mine did that. I adjusted the needle jet (put circlip on lowest position) and that seemed to do the trick.
kustommusic
Post by kustommusic » Thu Aug 07, 2008 4:28 pm
That is covering up the problem,you haven't fixed anything yet! Also for DJbarcy, Have you checked your fuel supply from tank to carb? that could be restricted. But I'm inclined to agree with LM, you dont have a clean carb. Kustommusic
djbarcy
Post by djbarcy » Thu Aug 07, 2008 8:04 pm
Okee dokee
I will pull the carb off tomorrow and go through it again.
I'll let you know how it works out
Thanx a bunch guys!
dan
Dan Barcy
'65 305 Dream
Geeky160
Post by Geeky160 » Thu Aug 07, 2008 9:14 pm
LOUD MOUSE wrote:Slide installed with the cut away toward the air side? (visible from the intake).
Hose on the brass tube at the bottom of the float bowl?. ..............lm
djbarcy wrote:Yes
LM, I thought we were not supposed to attach hoses to the brass nips under the bowl?
djbarcy, don't forget the orings on the idle screws.
'67 CL77 (337, gears X'd)
'65 CB160
djbarcy
Post by djbarcy » Fri Aug 08, 2008 6:50 pm
It was the O ring on the air/fuel mixture screw.
Took her for a ride and the motor is very strong.
Now I just need to stop the usual fuel leak from the gas cap. But, a rag in the pocket takes care of the seepage for now.
Sunday is a memorial ride for a police officer killed on duty down here so I am thrilled that I will be able to participate.
Thanx so much for all your help.
Dan
Dan Barcy
'65 305 Dream
Post by LOUD MOUSE » Fri Aug 08, 2008 7:21 pm
You are correct and fellers put them on there and have similar problems. ..............lm
djbarcy wrote:Yes
