After a summer of distractions, I'm back at it and almost done with my engine rebuild. Silver says the green o-rings go around the locater pins that are between the cylinders and the cam unit. I'm fine with that.
Are there o-rings that go around the pins that are between the case and the cylinders, or is the gasket all I need? My diagrams are unclear on this and Silver says nothing (which might be a hint).
Advice appreciated.
Top End Rebuild: Location of O-rings...
Re: Top End Rebuild: Location of O-rings...
They go on the knock pins at each front corner between the head and cylinders. ..........lm
305explr wrote:After a summer of distractions, I'm back at it and almost done with my engine rebuild. Silver says the green o-rings go around the locater pins that are between the cylinders and the cam unit. I'm fine with that.
Advice appreciated.
RIDE IT DON'T HIDE IT!
