1967 CL77 kick starter joint
The kick starter joint on my 67 CL77 has cracked. It's the coupling joint and not the kick start arm. I had the local welding shop TIG the crack, but the splines are still slipping around the shaft - thus unable to kick it. Any thoughts on a replacement or conversion ? Thanks in advance !
Re: 1967 CL77 kick starter joint
I can sell ya a good usable one. .............lm
Freddy wrote:The kick starter joint on my 67 CL77 has cracked. It's the coupling joint and not the kick start arm. I had the local welding shop TIG the crack, but the splines are still slipping around the shaft - thus unable to kick it. Any thoughts on a replacement or conversion ? Thanks in advance !
RIDE IT DON'T HIDE IT!
