Access cover missing on a '66
I was noticing that other Dreams have a what seems to be a clutch cable access on the engine side cover. My '66 doesn't have one - any one know why this was changed?
eyedragaknee
- Contact:
side cover
I might have one if you decide to replace it.
georgeorge
albano.martins
Clutch cable
Hi byrdman76!
I have a doubt in your dream clutch cable.
I would like to know, why did you put the clutch cable outside the fuel tank, because in my c77 n c72 i put them inside.
I know in ca95 to replace a clutch cable, you had an access, a case (left side), that made the clutch cable replacement easier, without disassembling the side cover.
Thanks,
Albano Martins
By the way, if you guys had a picture of the old arly CA models with the clutch cable coming through right side cover, just to see.Byrdman's right... his is different. mine is different than his anyway. My cable enters the case in the same spot, but he means that his has no rubber cap just above the grease nipple. Mine has a rubber cap about an inch in diameter just above the grease nipple. hmm...
Thanks,
Albano Martins
