1968 CL-77 with a CB-77E mtr#, normal?
305smitten
Post by 305smitten » Tue May 31, 2005 6:31 pm
I have a 1968 CL-77 Honda Scrambler. I believe the &quot;year&quot; model of 1968 to be accurate as it has chrome front/rear fenders and the tank &amp; side covers are painted &quot;candy orange&quot; as listed in the big Honda MC Identification guide. <br /><br /> While doing some minor R&amp;R work yesterday I noticed for the first time that the engine # is a CB-77E! I'm sure a stock engine should be a #CL-77. <br /><br />My question is this - as the 1968's were end-of-the-run for the 305 Hondas did Honda ever put any CB-77E engines in the last of the CL-77 frames?? Or is it more likely that a prior owner of my bike transplant a CB-77 engine into a CL frame? Everything looks stock &amp; accurate on this bike other than the &quot;CB&quot; engine #.<br /><br />Bill Gray, Lexington, Michigan
Bob Simmons
Re: 1968 CL-77 with a CB-77E mtr#, normal?
Post by Bob Simmons » Thu Jul 07, 2005 11:16 am
Bill: Are the numbers close to each other or very far apart? Also do you have a tach on your CL? Bob
305smitten
Post by 305smitten » Sun Jul 10, 2005 12:36 pm
Bob -<br /><br />The engine &amp; frame #'s are FFAAARRRR apart. The CB77E engine number (CB77E-1043366) is 21,268 lower than the frame number. <br /><br />- (by contrast my &quot;1969&quot; Dream's engine number is 4,933 lower than the frame number, my 1966 Dream's engine number is 14 lower than the frame number, my mid-60's SuperHawk's engine number is 39 higher than the frame number) -<br /><br />And no there is NOT a tach on this 305 scrambler - just a speedometer &amp; odometer in the black headlight nacel, there is a small blue light (I believe the high beam indicator) located at about 2-o'clock on the headlight housing just behind the chrome headlight rim.<br /><br />I'm guessing that based upon the &quot;huge&quot; difference in engine &amp; frame numbers that an after-the-fact engine transplant was done at some point after this CL77 frame left the factory??<br /><br />Thanks<br /><br />Bill
