Front fork seal orientation?
gac123
Post by gac123 » Wed Mar 18, 2009 11:11 am
It's been a while and I am finally reassembling my painted and rechromed parts. Before I rechromed I pulled the seals out of the housing. I'm ready to put new ones in but can't remember the orientation.
Open end up or down?
Any tips on gettingg them into the housing? Seems like it's going to be difficult.
Thanks,
Greg
Post by davomoto » Wed Mar 18, 2009 2:38 pm
Greg, open end down. A light coat of lithium grease on outer edge of seal, and a pipe, either metal or PVC to drive the seal in is a big help.
gac123
Reassemble front shocks
Post by gac123 » Sun Apr 05, 2009 6:06 pm
I have the seals reinstalled in my rechromed tube caps but now have three more questions.
What is the best stuff to clean out the tubes before reassembly. I don't want to damage the fresh paint. It seems like rinsing them out now would be a good idea before assembly.
There is a beveled ring that is part of the piston assembly ( see picture) Does the beveled edge go up or down. I can't be sure from my picture.
There is a retaining clip with a couple of waves in it that, I think, go in the chrome cap. Does it go above or below the seal?
I should have documented the disassembly but who knew that it would be apart for a year and a half?
Thanks for your help.
Greg
Post by davomoto » Sun Apr 05, 2009 6:33 pm
greg, what picture? The wave shaped ring goes on top of fork seal. The bevel faces down. I usually use brake parts cleaner for lowers, but it will do a number on the paint if you aren't careful! When disassembling parts that I'm not familiar with, I take lots of digital pics, and it's save my butt many times.
gac123
Post by gac123 » Mon Apr 06, 2009 8:38 am
Dave, Thanks for the reply. I tried to add a picture that I had annotated in Word but it wouldn't load. It wasn't too big so I don't know what was wrong. I don't have a clue what that bevel is for.
Greg
