Brighter headlight bulb?
Hi All: Does anyone know of a brighter headlight bulb that can be used in my 1964 CB77? I like to ride my bike home from work at night (I work 2nd shift) and its hard to see very far ahead even with the highbeam on. I have tried adjusting the headlight bucket, but the bulb just does not produce very much light. (I belive its 25w low / 35w high). I have tried a couple different stock bulbs, but they are all about the same. Thanx in advance, Carl
- h305 Moderator
Hey Carl, check out Paul Goff's site http://www.norbsa02.freeuk.com/goffybulbs.htm . I'm assuming, from your description, that you have a replaceable lamp and not a sealed beam. Your lamp's cap should have 3 'keyhole' slots around the flange; this denotes an American Pre-Focus cap (type APF). Goffy seems to have only 50/50W in 12V, which you'll probably get away with if you also change your stop/tail for an LED-type and swap out your rectifier for a modern silicon- or Schottky-diode type from Radio Shack.
In Europe we have (had, prior to P43- & then H4-flanged twin-filament headlamps) Bosch BA20d which differs from APF in fitting to the beam unit.
Further -
Rectifier info: http://www.honda305.com/forums/viewtopi ... highlight=
Taillight bulb info: http://www.honda305.com/forums/viewtopi ... highlight=
Incidentally, Goffy sends worldwide and accepts PayPal.
Further -
- Contact:
First make sure that your reflector is in perfect shape, if not replace it.
The CB72 has the same headllight as a CB400F. There are a lot of aftermarket replacement reflectors with different types of bulbsmade for the CB400F, like halogene H4.
I have a Xenon bulb fitted in a CB400F H4 reflector for my 67 CB72.
A Xenon blub is 35 Watts, H4 consumes more.
A reflector with H4 bulb is fitted in my 62 CB72, it's working fine with another rectifier like steve mentioned,
- Contact:
Go for the H4 / CB400F aftermarket reflector,
Forget the Xenon, the xenon option is much more complicated, it needs a stabiliezed power supply at all times, a ballast, and lot of re-wiring too.
I forgot that I made all the changes to have such a stabilized power suply.
A new modern rectifier is ALWAYS better, because of its efficiency, keep the old one for shows only.
So aftermarket reflector from a CB400f, H4, and a new rectifier will work for you.
In what shape is your reflector ?
- Contact:
Yes, I did this before I converted to even more light with the xenon, it worked.
I switched to Xenon because I wanted more power reserves for the Garmin GPS and a few other things.
If the H4 doesn't burn or is weak, check strength on your magnet of the dynamo,
Before you switch to H4, you can check this with a H4 bulb connected directly to the wires of the headlight (would take half on hour to find out).
