What would you pay?
What would you pay?
I am looking at 66 cb77 that had a surface fire on one side due to a stuck petcock, took out most of the rubber on the left side (tank cover, seat etc) He wants $500 but that seems a bit steep. What do you think?
I would offer him 400 for it, it's worth that in parts. I would be more concerned with any aluminum in that burn area, make sure nothing like that melted. Engine cooling fins, carb etc. Does the engine turn over? Check on the harness as well as it runs close to that area. Most if not all of the destroyed pieces you mentioned are available some cheap some not. I think he did you a favor on that seat (kidding) good luck.
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
1966 CL77
1965 CB160
1974 Triumph T150V
If the mufflers have no holes and are two piece mufflers, it has an original honda turn signal switch and a uncut front fender.
You have roughly $450.00 in parts right there , I would low ball and work your way up. If it is your first project I'd buy see what you can do with it, worse case you can part it out.
Good Luck,
Kirk
Good Luck,
Kirk
2-1966 CB77 Projects
1965 CB77 Partsbike
1967 scrambler pile of parts
1972 Cb350
1965 CB77 Partsbike
1972 Cb350
