I bought a 1967 Superhawk to do a resto about a year ago, as a total beginner. One of the first things I did was remove the tank and take it to a radiator shop to get the rust removed. As soon as the acid hit it, it sprung about a dozen leaks, totally shot. I had them toss it out.
I bought another tank on ebay, and went to reassemble with the parts from the first tank. That's when I noticed the second pipe coming off the right side. I didn't remember there being one on the tank I'd taken off, and I brought the petcock down to my local old honda guy. He took one look at it and told me it 'wasn't from a Superhawk' since it didn't have a second inlet. The place the second inlet goes was there, but it was plugged, and looked like it had been plugged by Honda. Anyway, I found a used petcock to match my tank and entered the world of very sloppy gas tank removals I'm sure many Superhawk owners are familiar with.
I've moved since, and met a new 'old honda guy' who tells me that sometime in 67, Honda discontinued the right side fuel line scheme. That would mean I'm not insane, and I did have a 'one-sided' tank. Anyone out there care to weigh in on this? My first mechanic friend still insists there were never any tanks without the right side outlet pipe.
Superhawk fuel tank with no right side outlet pipe?
Steve is correct, as is your " new old honda guy" !And as you state, fuel tank removal is a drag. I personally plug both ends so I don't have to drain the tank every time I remove it. You do lose a little capacity on reserve, but in an emergency you could just lean the bike over to slosh the fuel to the other side. Motion pro make a quick disconnect that you can install in the crossover line, that won't flow fuel when disconnected. Be sure to get the one that stops the flow from both sides, around $50.
Gunner_CAF
I had to remove a full tank not long ago, and it was a pain. I used a surgical clamp to pinch the crossover line to take the tank off. The clamp didn't totally stop the fuel from leaking, but I could quickly remove the tank without leaking too much fuel. Putting it back on was a little slower so this didn't work well. I drained the tank into a gas can, then filled it again after the tank was on.
Gunner
Gunner
Just checked motion pros' site. $28.50 for a dual shut off. Here's a link.
http://www.motionpro.com/motorcycle/too ... couplings/
