CL77 Rear Shock Disassembly
BillC
Post by BillC » Tue Mar 16, 2010 1:43 am
Could someone describe how to disassemble a rear shock ("cushion" as the Honda manual calls it) on a CL77.
Post by davomoto » Tue Mar 16, 2010 10:58 am
I use a tie down, looped over a beam. Put a long bolt through the top eye on the shock, hook the ends of the tie down on the bolt, and then pull down on the top cover. There is a split ring on top of the cover which can be removed when the spring is compressed. . Make sure to adjust the spring preload ring to softest setting, and an extra pair of hands helps a lot.
Davo
BillC
Post by BillC » Wed Mar 17, 2010 12:29 am
Thanaks for the info. Davo, definately a two person job.
