Need Part Number for Crankshaft 20mm Socket
Ilbikes
Post by Ilbikes » Sun Apr 25, 2010 11:31 am
Guys, I cannot find the part number for the large 4-tooth 20mm sprocket needed to remove the crankshaft sprocket nut. I have a new one I bought for the Black Bomber, but this one is much larger.
Thanks,
Gordon
greg78gs750
Post by greg78gs750 » Sun Apr 25, 2010 3:09 pm
large flat dull chisel worked for me.
Ilbikes
Post by Ilbikes » Sun Apr 25, 2010 7:12 pm
Nope, won't do that. There is a proper torque and a proper tool. I want both. I would make one from a metric socket if I can't find the factory tool.
Thanks,
Gordon
greg78gs750
Post by greg78gs750 » Sun Apr 25, 2010 8:41 pm
looks like you might want to go ahead and manufacture one. my shop manual shows a "4 prong special tool" but it is a t-handle affair tightened with a hammer with no apparent way to measure torque value.
im sure someone has a better answer than me.
Re: Need Part Number for Crankshaft 20mm Socket
Post by LOUD MOUSE » Sun Apr 25, 2010 8:52 pm
I'll get a pic of the tool I use for this nut and the cam sprocket nut.
Will try to get it on tomorrow. .....lm
Ilbikes wrote:Guys, I cannot find the part number for the large 4-tooth 20mm sprocket needed to remove the crankshaft sprocket nut. I have a new one I bought for the Black Bomber, but this one is much larger.
Thanks,
Gordon
jensen
Post by jensen » Sun Apr 25, 2010 11:56 pm
PN number is 1700113 according to the Honda tool book 2nd edition, printed in 1971
I ordered this part in the past, but where not available anymore,
Post by 305 » Mon Apr 26, 2010 6:38 am
if you have access to a lathe and mill it would be easy to make one , or modify an old socket to work
when small men begin to cast long shadows it's a sure sign the sun is setting
