Anyone know where to find some 'good' keihin float bowl gaskets? I've got a '65 cl77 w/ 26mm carbs and have used both the Sudco and Keyster kits. The bowl gaskets seem to swell and once used can not be used again. Any suggestions on using different material to make your own or a different brand that offers a good reusable gasket.
Thanks,
Chris
Keihin float bowl gaskets
gaskets
If you are careful, you can trim these gaskets back and keep them away from the float. I've had to perform this surgery a couple times with success. Save the cash for more important issues. IMHO,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,RW
Good luck on finding any which don't swell some.
I dry them and let the sun do it's job and I find they are good for a couple of installs. .............lm
sparks454 wrote:Thanks for the input, but I have already thrown them away. When I took off the bowl, they were 1/4" longer than when I put them in. Have to buy some new ones. Thanks.
