Restoration Of Front Shock Absorbers
michael-nadav
Post by michael-nadav » Fri May 14, 2010 6:51 am
Hi all,
Does Anyone have instructions how to take apart the front shock absorbers On a Honda CB77 (i mean the hydraulic chamber)? how do i separate the active fork from the fixed fork ?
Michael
Post by davomoto » Fri May 14, 2010 11:32 am
Steel or aluminum sliders? The steels have a threaded on chrome seal holer that a pin wrench, or a belt wrench can be used to unscrew them. They can be a bear, or sometimes they spin off easliy. Once unscrewed, you can seperate the tube from the slider by pushing down on the fork tube, and pulling up in a slide hammer type of motion.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
michael-nadav
Post by michael-nadav » Tue May 18, 2010 2:55 am
Thank for the tip ,i managed to opened them .
Can you please recomand what kind of brand of oil should i use ???
teazer
Post by teazer » Tue May 18, 2010 8:58 am
The perennial question - what oil should I use in my xyz? There are as many opinions out there as there are riders.
We all differ and we are all right (in our own minds at least).
What I use is Fork Oil and in a CB77 I'd use 30wt or 20W if you are light and the roads around you are smooth. 30 is not always easy to find and I usually end up buying a case. It's available on line.
Modern bikes have completely different fork internals and use much thinner oils to work in their smaller orifices.
You could probably get away with motor oil if nothing else was available, but Fork Oil is better IMHO
Post by LOUD MOUSE » Tue May 18, 2010 9:07 am
HONDA recommends a 10W HONDA oil. ............lm
michael-nadav wrote:Thank for the tip ,i managed to opened them .
teazer
Post by teazer » Tue May 18, 2010 1:46 pm
Thanks LM. That surprised me.
mobilyte
Post by mobilyte » Thu Jun 03, 2010 5:12 pm
i noticed the 10wt honda branded fork oil (bottle said developed by showa) also claimed to be compatible with any application requiring atf.
