just got the bike and was wondering the year?? engine# cb77e-1009225
Frame # 1009633
Should the frame and engine numbers match on these bikes?? thanks for any help.
serial numbers ??
- h305 Moderator
Welcome! Probably '65. Actual YOM for 7-digit numbers is sketchy -- just documented as '65-'67. Look for the year tag on the wiring harness; it's under the tank (you have to remove the tank to find it -- that's fun!). Appreciate your letting us know here -- for the records that I'm compiling for those years.
Matching numbers are very rare for post-'63 bikes, but not unheard of.
Re: serial numbers ??
New to the forum but ya don't show your location. ..............lm
ote="arch379r"]just got the bike and was wondering the year?? engine# cb77e-1009225
Frame # 1009633
Should the frame and engine numbers match on these bikes?? thanks for any help.[/quote]
Frame # 1009633
found the tag
its a 1965. the kick starter shaft seems loose , any ideas whats wrong?
Re: found the tag
Remove the cover and check.
Probably a warn KS bushing. ........lm
arch379r wrote:its a 1965. the kick starter shaft seems loose , any ideas whats wrong?
