mis-matched crankcases
ricksd
Post by ricksd » Fri Jun 04, 2010 9:40 am
Out of the 3 junkyard engines I bought, CB,CA,CL, I can salvage 1 good set of crankcases if I put the CL top on a CB or CA bottom. Did Honda sell case halves individually, or did they make you to buy a 'matched' set of crankcases? If they wouldn't sell individual halves it's a good indication that they were machined as a set and not meant to be swapped around.
I don't have enough parts cleaned or bought to do a test fit- wondering if I need to start looking for a matched set of cases.
Rick
Post by davomoto » Fri Jun 04, 2010 11:21 am
I have mixed and matched cases with no problems. Just make sure all oil passges etc line up.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Re: mis-matched crankcases
Post by LOUD MOUSE » Fri Jun 04, 2010 11:47 am
All the wet sump cases can be replaced as one piece.
One thing to look for is that the bottom case must have the 2 mounts for the primary chain tensioner.
That was a change after the EARLY engines didn't come with the tensioner but is needed if ya going to run the engine at speed.
No real external changed can be seen. ...........lm
ricksd wrote:Out of the 3 junkyard engines I bought, CB,CA,CL, I can salvage 1 good set of crankcases if I put the CL top on a CB or CA bottom. Did Honda sell case halves individually, or did they make you to buy a 'matched' set of crankcases? If they wouldn't sell individual halves it's a good indication that they were machined as a set and not meant to be swapped around.
Rick
ricksd
Post by ricksd » Fri Jun 04, 2010 9:27 pm
OK, thanks, case(s) closed
Rick
