CB77 Valve Guides
MBellRacing
CB77 Valve Guides
Anybody have a good source for all the bits required for the CB77 as far as valve retaining and sealing (guides)? I need these VERY quickly. Thanks!
MBellRacing
...nevermind. Ohio cycle has them all but doesn't show them in the parts list. If anybody is interested in the future:
CB77 Valve Keeper (2 per valve, 8 per engine): 14781-253-010 --- $2.50 ea.
CB77 Intake Valve Guide (1 per valve, 2 per engine): 12021-268-000 --- $11.00 ea.
CB77 Exhaust Valve Guide (1 per valve, 2 per engine): 12023-259-000 --- $12.00 ea.
Bike Bandit has the guide rings as well for a couple bucks.
jensen
- Contact:
Yes, that's the way to go Dave. Instead of the freezer, I use a small peltier cooler, it will bring the temperature down to -70 to -80 degrees Celsius, but a freezer will do.
If you want to be sure that everything is aligned perfect (guide, valve, valve seat), you have to cut the seats after installing the guides and reamed them.
Ream the valves a day after pressing them into the head, and make sure everything (and that includes the reamer) is on a temperature of 18 to 20 degrees Celsius (room temperature).
Before installing the valve, make sure the stem is straight within 0.01 - 0.02 mm, if not, don't use it.
If the valve is bend a little, there's a chance that the valve sticks in the guides and touches the piston, especially when the guide is new, and not aligned perfectly.
I always walk this way, but that doesn't mean that another method is not good. It's expensive, when you can't do it yourself, and not always needed.
Sometimes I maybe loose the perspective of the hobby bike, as Ed pointed out all to clearly.
I use these bikes as a daily rider. A modern (new) bike will set you back 5.000 to 15.000 Euro, if I want a classic CB72 as a daily rider, I can spend that kind of money on a CB72, and things are in perspective.
BTW, a good reamer will set you back a lot of $$, but if you're into these bikes, and do it more often, it's worth the money (maybe overdone, but a reamer should always turn in one direction (clockwise in most cases) while reaming and pulling it back, and never ever turn it the other way.
The reason for this is that the small particles of metal will ruin the surface when the reamer is turned the other way.
If you cut a thread, it's the other way around, turn it clockwise one or two turns, and than a half to a full turn anti clockwise to brake the metal particles.
Always use a a good thread cutter set (don't know the English word for it) and preferably a set with 3 cutters. Always use a cutter oil, especially in aluminum. Always try to place the cutter straight in the object, preferable with a help of a 90 degree steel angle.
