Kick Start Has me baffled
Davo
Post by Davo » Sat Jul 10, 2010 11:10 am
First of all thanks to everyone here been a big help. I have looked at my Bill Silver guide and can't seem to figure out how to fix the kick start. I have a 69 and 65 CA77, I pulled the kick start and spring off the 65 to put on the 69. When i attempted to reassemble the spring in the resting position is what appears to 180 degrees wrong. (the kick handle points to the ground) I have looked through many posts about preloading the spring yet it still returns to the rest position up side down. any help would be great.
Post by davomoto » Sat Jul 10, 2010 3:07 pm
Davo, wind it back further, slide it over the splines. It may take e few attempts to get indexed correctly. Unless you re-assembled it incorrectly of course.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Davo
Post by Davo » Sat Jul 10, 2010 3:57 pm
I will give it a try thanks. when winding it i should be going counter clockwise with the kick handle. What keeps it from returning to it's rested position.
Post by davomoto » Sat Jul 10, 2010 6:45 pm
Yes, wind it counter clockwise. When you slip it over the splines. it should only return as far as the internal stop for the kickshaft will allow.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Davo
Post by Davo » Sun Jul 11, 2010 2:39 pm
where is The internal stop for the kick start stop located? The kick start shaft that the spring and handle connect to will rotate clockwise without a stop. is this correct? so when i load the spring no matter how far i have rotated the spring counter clockwise it will spin back to the rested position upside down. maybe still have assembly issue. thanks for your help.
Post by davomoto » Sun Jul 11, 2010 3:35 pm
Davo, the stop is in the transmission. Ther is a pawl, spring, and a pin. Sounds like that is where your issue lies. You have to split the case to access it.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Davo
Post by Davo » Sun Jul 11, 2010 6:04 pm
Not what I wanted to hear but thanks. was hoping not to have to split the case but I think the clutch plates are stuck as well so I guess I will get to learn more as i go. thanks for your help. I am sure you will hear from me again. Davo
