No more power
versuspop
No more power
Post by versuspop » Wed Jul 14, 2010 9:43 am
Once I hit 4th gear the bike will stay at constant speed, but I can not accelerate in 4th. Any thoughts? Is this normal?
65 CA77
66 CB77
71 CB450
73 CB350F
brewsky
Post by brewsky » Wed Jul 14, 2010 7:02 pm
Could depend on several factors such as your weight, and any other load on the bike, going uphill, wind direction, whether you have a windshield etc.
With mine, if I'm on level road with no headwind, no problem accelerating in 4th.
If on a slight hill, or with headwind gotta go to 3rd.
joeweir1
Post by joeweir1 » Thu Jul 15, 2010 2:49 pm
I 2nd Brewsky's comment.Is your clutch slipping?
versuspop
Post by versuspop » Thu Jul 15, 2010 7:47 pm
joeweir1 wrote:I 2nd Brewsky's comment.Is your clutch slipping?
not exactly sure how to tell... or the difference between drag and slip, for that matter...
65 CA77
66 CB77
71 CB450
73 CB350F
Goodysnap
Post by Goodysnap » Thu Jul 15, 2010 8:01 pm
Slipping means RPM's increase while speed remains the same in a given gear. Dragging is the clutch not releasing and in the bike still tries to move with the clutch in or released.
64' CB77
65' CB160
joeweir1
Post by joeweir1 » Thu Jul 15, 2010 9:01 pm
The reason I mentioned the clutch slipping is that on one of CA77 engines that had the original all fiber disks in it when I tried to accelerate quickly in 4th gear I could feel the clutch slip which indiacated worn out disks after double checking clutch adjustments.
versuspop
Post by versuspop » Fri Jul 16, 2010 7:07 am
I don't think it is an issue with the clutch. I think I have worked out the issue somewhere between lower expectations and a carb adjustment.
joeweir1 wrote:The reason I mentioned the clutch slipping is that on one of CA77 engines that had the original all fiber disks in it when I tried to accelerate quickly in 4th gear I could feel the clutch slip which indiacated worn out disks after double checking clutch adjustments.
65 CA77
66 CB77
71 CB450
73 CB350F
