this is the washer that sits on the oil seperator shaft between the seperator cap and the oil cover. i bought a second parts bike and when i pulled the side cover off i looked at the inside of the oil cover and it was a mess.
but that washer is gone and this engine is pretty much a boat anchor without it. where can i find a replacement or a substitute?
if you have a part number for mcmaster-carr that would be great. i tried looking on my own and got lost.
let me know
flat bearing part # 15493259000
THIS WASHER WILL WORK
I found a honda washer that is still available and is a good subsitute for the original part #90451-155-000.
fast fred
fast fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
sounds good
thank you fred
someone at the redlands honda shop mentioned your name to me and suggested i go to your website but he wasn't sure if you had one or you used to have one.
can't remember his name but he said he's been there forever and you would be someone with alot of helpful knowledge.
you wouldn't happen to have a photograph of an early joint,clutch wire part #22875259020 ?
if i could see one i can make em for xmas presents from flat bar alluminum. might not be original but it will get the bike on the road and i'm good with that.
thanks fred
take care
thanks fred
take care
