Honda CB450E
CB160, CB350, CB360, CB450
Ironman
Honda CB450E
Post by Ironman » Wed Oct 19, 2005 5:21 pm
I can't find out anything about this model. all I know is the serial number for the engine (CB450E-3008318). I need some info on this model because we currently have this engine on a custom dunebuggy and my dad made it a long time ago. Now a clutch part is broken, and i need to find out about it so that i can find parts for it.
bill440cars
What Do I Have?
Post by bill440cars » Thu Apr 20, 2006 8:03 pm
Ironman, What you have is aCb450K1 that was sold from 1968-69'
Judging from the serial number, I'd say you would be safe to say that it
is a 1969. Thing is, alot of 450 engine parts will fit quite a few years. If
you will go to crotchrocket.com, you'll find access to online parts
manuals for these and others. After you find the p/ns for what you need,
check with them to see if yhey have the parts. Hope this helps. Later on,
Bill
tbpmusic
Post by tbpmusic » Wed Jul 02, 2008 9:40 am
Bill -
Do you have a source for matching engine numbers to models??
All my info uses frame numbers, and that number rarely matches the engine number (I've only seen one that did, long ago).
bill2
Gun
Post by Gun » Wed Jul 02, 2008 4:25 pm
the difference between the frame and the engine number set up would be CB450-3008xxx instead of CB450E-3008xxx, seeing as how they would have been manufactured close the same time. off by maybe a few hundred.
you aren't worrying about a frame however, just an engine, so use the engine number, it will be a correct assesment of year.
'65 CB77
'66 CB450k0
'93 HD FXR
denfam4
Post by denfam4 » Wed Oct 08, 2008 11:00 am
For great info and other resources for the CB450 you can go to:
http://groups.msn.com/HondaCB450DOHC
I have a 71 with 68 body work.
Re: Honda CB450E
Post by e3steve » Sat Nov 08, 2008 5:28 am
Ironman wrote:I can't find out anything about this model. all I know is the serial number for the engine (CB450E-3008318). I need some info on this model because we currently have this engine on a custom dunebuggy and my dad made it a long time ago. Now a clutch part is broken, and i need to find out about it so that i can find parts for it.
Go with the same number, omitting the 'E', for parts ordering. The 'E' denotes 'engine'; the actual frame number shouldn't be far off the engine number, and it's the frame number that parts-ordering usually revolves around.
Try Ed at Western Hills Honda Yamaha: ed@westernhillshondayamaha.com
You should find the part you need on their online fiche:
http://www.westernhillshondayamaha.com/ ... detail.asp
The CB450 starts in 1966 year model.
