Before I brake it, I'll ask !!
fab
Post by fab » Thu Oct 20, 2005 3:11 am
Please tell me ,There must be a trick to undoing this nut????<br />I thought I better ask you guy's before I go applying any heavy handed methods . I don't want to brake it . This nut is VERY tight , I'm sure one of you guys would have more experience than me about this Steering nut . I'm trying to drop the forks &amp; tree out so I can sandblast the frame . Here's a pic !! I see that I'm not the only one asking advice on it's removal.<br /> thanks Peter
FLYHAVEN2001
Re: Before I brake it, I'll ask !!
Post by FLYHAVEN2001 » Thu Oct 20, 2005 6:58 am
Try heating and or soaking it with blaster for acouple of days. I used a pipe wrench with a length of pipe to extend handle for more leverage on one. May need a helper to hold the frame still.
fab
Post by fab » Thu Oct 20, 2005 7:08 am
FLYHAVEN2001 wrote:<br />Try heating and or soaking it with blaster for acouple of days. I used a pipe wrench with a length of pipe to extend handle for more leverage on one. May need a helper to hold the frame still.<br />
<br /> Hi Thanks , So it's just a normal nut ? Nothing else that holds it on but age ,rust &amp; being tight , Now I know it does just unscrew I will be a bit forceful with the dam thing .<br /> Thanks Peter
prima5star
Post by prima5star » Thu Oct 20, 2005 9:16 am
It has a lot of fine shallow threads so any crap in there really does make it hard. use a small wire brust to get the threads as clean as you can before you start trying to remove it.<br /><br /><br />Matt
Matt
Also into Alfa Romeo Giuliettas and Giulias! Looking for a Giulia Super.
fab
Post by fab » Thu Oct 20, 2005 7:01 pm
Got IT off !!<br /> , Had to heat it up a little , but then it came off with no dramas. Once I knew what type of Nut it was , it wasn't a problem . This payday I'll buy a Manual !!<br /> Thanks for your help / Peter
