Getting the rear tire on the swing arm...
Sascha
Post by Sascha » Thu Nov 25, 2010 9:47 pm
Hey guys,
Can I ask for you to post pictures of the rear axle and how its mounted... having some difficulty getting it on...!??!
-Sascha
brewsky
Post by brewsky » Thu Nov 25, 2010 11:16 pm
Look at the parts diagram to see where the pieces fit.
Online if you don't have a book.
Mount the axle collar, sprocket portion of the hub, small spacer on the right, and finger tighten with large nut.
Add the rubber cushions.
Raise the wheel with brake plate and insert axle from the left side.
http://www.westernhillshondayamaha.com/ ... &fveh=2855
Sascha
Post by Sascha » Fri Nov 26, 2010 10:18 am
Where do the rubber cushions go?!
-Sascha
brewsky
Post by brewsky » Fri Nov 26, 2010 11:18 am
Into the right side of the hub, or the left side of the sprocket drive
Sascha
Post by Sascha » Fri Nov 26, 2010 2:34 pm
Thanks for the convo today Brewsky, needed to be sure I wasnt digging my own grave when I put the tire on! ;)
-sascha
brewsky
Post by brewsky » Fri Nov 26, 2010 7:06 pm
No problem!
I just re-assembled the rear of on old Elsinore and got it wrong...and I had the parts manual!
It worked perfectly in my head....just didn't work out on the bike!
But practice makes perfect they say.
