I'm considering something like this in the future, but I thought I'd see if anyone else had tried something familiar before. What is the correct timing for a stock Cb77?
I saw that, but I really enjoy trying new stuff and saving some money. I can get two of these for under $70 and I should have most of the materials to build the plate and disc in the garage. So, feasibly I could make the entire system for under $80. It doesn't require an electronics box, it just hooks directly to the coils. When the magnet passes over the module, it fires the coil. Fairly simple design.Sascha wrote:They sell electronic ignitions on the site...
-Sascha
Well, I'll admit that I'm not familiar with the ignition system on the 305, but I can't see how it's any different than any other point system. When the contacts break, the coil fires. It's that simple. The device above just replaces the points and condenser and tell the coil to fire when the magnet passes over it. Now, if there is interference because of the electrics or the stator, then it might not work, but I think it is far enough away to prevent that.cyclon36 wrote:Looking at the one that's available for now: http://www.honda305.com/ignition/
It doesn't seem as easy as you describe. I'll admit though I'm not an electronics guy. I'm all for simplicity though. If you can make something work that has less parts and is as reliable, I'd buy it. I'm sure others would too.
Check out this site. It's very informative with info on both points systems and electronic systems.Wilf wrote:I would be interested in knowing exactly how the passing of a magnet interrupts the primary coil voltage resulting in the firing of the plug. Somehow the passing magnetic field has to open the coil primary circuit--how is it done?
Wilf
