Need further SPECIFIC rim info
Dr. Frankenstein
Post by Dr. Frankenstein » Tue Dec 14, 2010 12:01 pm
Hi All;
Not to beat a dead horse, but about the rims: can anybody please tell me, what angle do the spoke holes need to be for a 1962/1964 CA77 so those big honkin' hubs will fit onto a new rim..?
And they ARE 36-hole, right? So ideally, a new rim should be 16x3.25, 36-hole, and...(spoke angle)??
Does anybody know the spoke angle??
I MAY be on to something, but I need this specific information, especially any spoke angle specs...
And again, to review:
1964 CA77 305 Tires/Wheels
RIM: 16x3.25
Tire: 3.25x16 (yes??) OR 110/90-16 ??
Spoke Angle: ??
Is this correct...?
Thanks!
John
brewsky
Post by brewsky » Tue Dec 14, 2010 1:00 pm
John,
The wheel size and the tire size are two different measurements.
The stock tire size for the Dream is 3.25/16
The correct rim size for that size tire should be 2.15" also called WM3
I believe the 2.15" is actually the dimension between the bead surfaces of the rim.
A 110/90 is probably too wide for a replacement size.
I'm not sure about the spoke angle.
This chart was linked in a previous post:
http://www.hagon-shocks.co.uk/WheelTab.htm
Post by G-Man » Tue Dec 14, 2010 3:06 pm
John
This is the type of information you need to quote. The spoke pitch on the hub relates to the spoke angle.
http://www.central-wheel.co.uk/rims/rim ... edure.html
Cheers
