CA77 305 with odd clump of Green Grease
bbap
Post by bbap » Tue Dec 28, 2010 2:47 pm
Back at the project and cleaning up the engine before I start removing the heads and noticed an odd lump of green grease pushed in just above the spark plug on the right hand side of the motor. It's evergreen in color (how appropriate). Is there any importance on putting this back? The amount is about 1/8 of a cup and it's all jammed into two fin sections just above the plug hole - on the right side (between Points cover and Spark plug hole).
Thoughts?
If that question is not sufficiently dumb, how 'bout this one: How do I see a message that was sent to me through this forum? My email apparently blocked something sent to me. I'll figure it out in about 2 days unless someone comes to my rescue!
Thanks!!
Steve
engine: CA77E-3161XX
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
Re: CA77 305 with odd clump of Green Grease
Post by LOUD MOUSE » Tue Dec 28, 2010 3:08 pm
Would you please check the engine numbers.
I think I know what the separation is.
Check the letters and numbers. ............lm
bbap wrote:Back at the project and cleaning up the engine before I start removing the heads and noticed an odd lump of green grease pushed in just above the spark plug on the right hand side of the motor. It's evergreen in color (how appropriate). Is there any importance on putting this back? The amount is about 1/8 of a cup and it's all jammed into two fin sections just above the plug hole - on the right side (between Points cover and Spark plug hole).
Thoughts?
Thanks!!
Steve
bbap
Post by bbap » Tue Dec 28, 2010 4:10 pm
Will do!
Engine: CA77E - 316120
Frame: CA78 - 311116
THoughts?
