Coil on my AC Generator CA77 Dream 300
suzukid01
Post by suzukid01 » Sat Feb 11, 2006 7:08 pm
Question: One of the 6 coils on the AC Generator has a break in it. Will this effect the the charging on my bike? Also will this effect the Spark to the spark plug to be weak???? Any Info will be Thankful
Re: Coil on my AC Generator CA77 Dream 300
Post by LOUD MOUSE » Sat Feb 11, 2006 8:26 pm
As long as there are no wires broken the part will be OK. .........lm
suzukid01 wrote:Question: One of the 6 coils on the AC Generator has a break in it. Will this effect the the charging on my bike? Also will this effect the Spark to the spark plug to be weak???? Any Info will be Thankful
suzukid01
Post by suzukid01 » Sat Feb 11, 2006 11:24 pm
there is a break in 1 of the wound coils where it's wound is what I met. Will that cause a problem??? Thanks for the info
Post by LOUD MOUSE » Sun Feb 12, 2006 9:02 am
If you have a broken wire the part is bad. You may be able to splice it. Use a OHM meter amd measure from wire to wire and you should read "short" from each wire to each wire. There is a Yellow/Green/Red wire that should not read to anything until connected to the neurtral switch. ..............lm
suzukid01 wrote:there is a break in 1 of the wound coils where it's wound is what I met. Will that cause a problem??? Thanks for the info
ddrumman2004
Post by ddrumman2004 » Thu Jun 22, 2006 10:54 am
New member here and I had the same problem with the stator coil on my 76 Honda CB 500 T. My charging voltage was only 11.5 volts so I found a cycle salvage yard and bought a good used stator that fixed my problem.
cron
