kph speedo
mschehen
kph speedo
Post by mschehen » Fri Feb 11, 2011 6:19 pm
Have any of you ever converted a speedometer from kph to mph, if so what is involved.
Thanks
mschehen
brewsky
Post by brewsky » Fri Feb 11, 2011 7:24 pm
All you should need is a new face decal marked in mph.
mschehen
Post by mschehen » Fri Feb 11, 2011 7:39 pm
would it be accurate? I was thinking that they would not have the same ratios and that I would have to change something in the drive.
Post by G-Man » Sat Feb 12, 2011 4:27 am
There is no difference in the mechanical parts to the needle, just new labels to indicate the speed in different units. Many cars have both markings on the speedo nowadays.
You should be able to photograph or photocopy the dial from a km/h speedo.
The Odometer will read in miles still unless you change the gearing but speeds will be as accurate as the original speedo.
mschehen
Post by mschehen » Sat Feb 12, 2011 11:15 pm
Thanks for the help, I am ordering a new face from the company in canada and putting it back together.
Mike
cron
