Tire type for spoked wheels
Jethro
Post by Jethro » Sun Feb 13, 2011 11:45 pm
Just out of curiosity, is it ok to use a tubeless type tire with a tube on spoked wheels?
cyclon36
Re: Tire type for spoked wheels
Post by cyclon36 » Mon Feb 14, 2011 8:15 am
Jethro wrote:Just out of curiosity, is it ok to use a tubeless type tire with a tube on spoked wheels?
I can't remember where I read it, but I remember reading that the general rule of thumb is that if you use a tubeless tire with a tube, you have to get one speed rating higher than normal. The reason is, is that the tube tires build more heat on the inside than the tubeless do.
Goodysnap
Post by Goodysnap » Mon Feb 14, 2011 8:09 pm
I'd say you should be okay. Alot of tires are designated to be used for either one. If in doubt, check with the manufacturer.
64' CB77
65' CB160
