Hello, I've just been looking through the "bikes for sale" and came across a 1962 cb72 with a
WEBCO 350cc KIT - HARMAN/COLLINS DRAG CAM & SPRINGS - 305 CARBS.
If you bore out to 350cc do you use the barrels of a bigger CB or is it a resleeve of the original CB72 barrels.
Also what kind of gain is achieved as I have a 1963 CB72 that needs a complete restoration. I intend to use it for the road and the odd track day. Not racing though.
Any information is much appreciated.
Thanks H.
cb72 350cc ?
There are different ways to do it. No matter which way, the engine cases need to be bored on a 250 lower end. The stock 305 sleeves can be bored 4mm, but they are left quite thin. There's a seller on ebay that sells a kit that has oversized sleeves, cylinder must be bored to accept them. I have 2 and 3mm overbore kits for the CL72, you can stil use stock liners, no need to bore cases. Megacycle still offers a few different re-grinds for the cams, and hard facing for the rockers. It adds up to a lot of money for a little gain IMHO
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
With a Cb72, the replacement liners often are larger than the barrel muff and it's possible to machine right through the base of the fins at the front and back.
That's less of a problem with Cb77 barrels which have more metal in the middle for the larger liners.
A Webco 350 kit with H&C cam and light port clean up is a significantly faster bike that a stock CB77 and much more so than a stock 250 - according to tests from the time.
Drag cams typically have a lot of lift but not much duration and are excellent for those of us that "point and squirt" our way around a track. Great acceleration as a rule.
If the motor is not worn out or rusted solid it would be a great track motor in all probability.
Yes, the 305 barrel and head as the 250 head doesn't have clearance for the bigger piston. Cases need to be bored as well.
Sorry about the ambiguety on the cams. As Teazer stated the entire package will make a big difference in performance. The cams and hard facing of the rockers less so on thier own.
I have a CL77 that I bored 3mm over into the stock lining, and that made a really big improvement on it's own!
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
