Left side cover gasket source?
Jethro
Post by Jethro » Sun May 15, 2011 2:18 pm
Hi, just curious about what the best source is for a left side cover gasket?
Thanks, Jethro
pc13cb92
Post by pc13cb92 » Sun May 15, 2011 2:37 pm
I bought some sheets of gasket paper off ebay, along with some cheap hole punches, and then made my own, matching up to the side cover and old gasket. When fitted, no leaks no problems. Can now make as required.
Regards
Peter
1961 CB92
1961 C92
1964 C72
20000 FZS600
quidger
Gasket
Post by quidger » Sun May 15, 2011 9:05 pm
Got one from Ohio Cycle recently. Good quality item.
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
Jethro
Post by Jethro » Sun May 15, 2011 11:06 pm
Is this the part number? 11395-259-000 If so, is it really $19 from Ohio Cycle?. If it is then I could see why you'd be better off going with a home made gasket. Especially with the regular removal of that side. Good idea Peter!
Thanks, Jethro
Dgormley
Left side gasket
Post by Dgormley » Mon May 16, 2011 12:00 am
Jethro, I make my own, as Peter does.I usually get 2or 3 uses out of them....................D
Post by G-Man » Mon May 16, 2011 12:18 am
This one sounds a bit more reasonable, although I have to agree - making your own is much more satisfying!
http://www.classichondarestoration.com/ ... d_269.html
cknight
Post by cknight » Mon May 16, 2011 8:06 am
Check with your local Honda dealer to see if he has an NC gasket cutting machine. If he has the CA/CB/CL program, he can cut them out of modern gasket material (of the correct thickness). My local dealer offers this at a reasonable cost. Regards, Chase
