Front Chain Sproket
Rickytic
Front Chain Sproket
Post by Rickytic » Sat Sep 01, 2012 11:41 pm
Decided to take my CL77 down to the frame and restore it. When I took the right side case off the engine and removed the main drive chain I noticed the following.
The main drive chain sprocket (the small chain sprocket behind the right side case) appeared to be loose. The sprocket has two bolts in it that appear to be tight, however, I can rotate the sprocket right and left ever so slightly on the shaft, as well as slide it in and out also very slightly. The whole sprocket just seems to be loose on the shaft, is that normal?
Re: Front Chain Sproket
Post by LOUD MOUSE » Sun Sep 02, 2012 7:05 am
It's normal. ..................lm
Rickytic wrote:Decided to take my CL77 down to the frame and restore it. When I took the right side case off the engine and removed the main drive chain I noticed the following.
Goodysnap
Post by Goodysnap » Sun Sep 02, 2012 7:12 am
Hello Rick,
This area is a slip fit and will have some play in it over time. As long as the bolts are secure in the lock plate it wont come off. You can check it for excessive wear and maybe replace the less expensive sprocket.
Goody
64' CB77
65' CB160
Rickytic
Post by Rickytic » Sun Sep 02, 2012 9:24 am
Thanks to the both of you, thought that might be the case, just wanted to be sure.
Rickytic
Post by Rickytic » Sun Sep 02, 2012 9:27 am
Goody,
Thanks again for the float bowl gaskets, will surely use them when I put this thing back together.
Goodysnap
Post by Goodysnap » Sun Sep 02, 2012 12:01 pm
Rickytic wrote:Goody,
Your welcome!
64' CB77
65' CB160
